MrWizard
Aug 11, 2007Moderator
maybe it would help, if we just 'try' to refer to the 'common wire / white wire' and try to refrain from the 'neutral' term
the white common wire IS ALWAYS load carrying and only in a home RESIDENTIAL wiring is zero volts neutral to ground NOT to the hot,
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
