professor95
Sep 05, 2007Explorer
skyzoomer wrote:
To Professor95 or anyone else who has run an exhaust pipe from their generator,
If you feel the exhaust pipe after your generator has been running a while, what is the distance from the generator that you can hold your hand on the pipe without burning? I hope to transition from metal to PVC for my exhaust pipe using your info.
Thanks,
Skyzoomer
Forget the idea of using pvc or cpvc on the exhaust of the genset. Use 3/4" id metal and keep it 3 feet or less. If you must go over 3 feet, increase your size to 1" id for an absolute max of 6 feet. For each 90 degree bend in the pipe, take off a foot of legenth in the allowance.
Question about the transfer switch. Is it a 2 pole (240 volt) or single pole 120 volt? This fact will have a major impact on the gauge of wire you use and the load you can have attached. I need the answer before I can comment/advise.EDIT: Never mind the above question. I had the 116 switch confused with the 216. I now see it is strictly 120 volt, single pole. You are on the right track.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
