bobandcat
Sep 18, 2007Explorer
professor95 wrote:
I see no reason why you cannot build an enclosure below the gas tank. You would need to elevate the gas tank a few inches which would require some hacksaw work and re-welding on the upper frame.
When I cut my Champion frame, I used 1/2" black iron pipe inserted into the tubular frame and 1/4" bolts to fasten it together. No welding neceassary for those without a welder and it allow you to swing the fuel tank out of the way to work on the engine if needed.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
