skyzoomer
Oct 04, 2007Explorer
TubaPete wrote:
..snip..My understanding is the formula is
watt = volts X amps.
In which case you've got it right. No need to add or double anything.
Easy ways to remember two electronic formulas that I use and have never failed me throught the years are:
Power: P=IE
Think of a hot apple pie cooling on a kitchen window on a farm with electic power poles and lines in the background.
P is power in watts.
I is the standard symbol for current in amps.
E is the standard symbol for voltage in volts.
Ohms Law: E=IR
I = E/R
R = E/I
Think of voltage as the boss of everything. Therefore it stands alone on the left side of the equation or on top on the right side.
E is voltage in volts
I is current in amps
R is resistance in ohms
Using these two tricks for remembering, one can never get the formulas mixed up.
Skyzoomer
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
