Wayne_Dohnal
Jan 25, 2008Explorer
Continuing the current waveform and power factor discussion, I captured a few current waveforms. I think their potential to confuse a voltage regulator speaks for itself. I wish I could capture the pictures using a Chinese generator, but I just don't have one.
This is an incandescent light bulb. Current is on the top, voltage on the bottom.
This is a compact fluorescent. I'm not surprised that the Kill-a-Watt doesn't care for it.
A conventional transformer-rectifier power supply.
A Eureka Mighty Mite vacuum cleaner. Note the noise in the waveform.
PD9160A converter with no load. Noise visible here, too.
PD9160A with 7 amp load.
Finally, PD9160A with 65 amp load. There's still noise on the waveform. It looks smaller because the trace is scaled down to fit the higher current reading.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
