professor95
Mar 05, 2008Explorer
Last night I finally got around to fiddlin' with the tri-digital meter that Champion is now offering on some of it's models. I have also been told that the meter will soon be available in kit form for retrofit on older models. I have no details on pricing.
I hooked the one I had received up to domestic power. The opening in my genset for the older electro-mechanical running time meter was larger than the new tri-digital, so I elected not to try and mount it on the genny. I have a small control pannel that will go inside the camper to start the genny and transfer power between the inverter and the genny. I have room to mount the meter on the inside pannel - I think it will be a neat accessory.
The meter only needs a connection to the 120 volt power source. There are two wires that connect to a push button. Each time you push the button, the meter cycles to a different function. This meter will obviously work on any brand of generator producing 120 volts. It is a really handy tool for adjusting the engine speed for the desired frequency.
VOLTAGE MODE
FREQUENCY MODE
RUNNING HOURS MODE
BOTTOM VIEW
VOLTAGE MODE
FREQUENCY MODE
RUNNING HOURS MODE
BOTTOM VIEW
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
