BFRXLT
Mar 22, 2008Explorer
I'm not an expert on generators or anything but the non-inverter generators are already turning at 3600 RPM. Inverter style generators are turning slower than that depending on the current load the are running. When you turn on an AC unit with a non-inverter generator it's already at speed while the inverter style generator has to actually speed up to power the load. I think that is part of the reason the inverter gens cannot start the AC unit where the non-inverter gens can.
That being said I have a power backup device that provides surge protection as well as over/under voltage protection so I don't have to worry about all that. The one I use has a built in surge protector and if the voltage goes over or under a preset voltage it will automatically adjust the voltage. There is also a methode to set the over/under voltage to what ever I want it to be.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
