professor95
Jun 10, 2008Explorer
crankshap1000 wrote:
The Flair originally was fitted with a genny that disappeared somewhere along the line.Since I had the original housing area with a door and the transfer switching already in place, I decided to use a champion 4000 watt genny from CSK to replace the original.I added a nice chrome extension pipe to the stock genny muffler and left about 2" of pipe through the screen in the genny door. I added a choke cable and clocked the pull start cord so it was accessable from the front.I added some extra rubber vibration dampening under the genny and also some sound deadening material to the original sheet metal surround
Thank you for sharing your success.
Helping fellow RVers to accomplish such innovations as yours safely and effectively has been one of the goals of this forum for several years. Many "ideas" have been floated - some sank and others stayed above water.
Your set-up sounds very nice. Is it possible to make some photos of your accomplishments and post them to the forum? If you are not familiar with how to do this, a photo hosting service is needed. I use Photobucket for my images. It is free and very user friendly. Of course, other services work equally well. In the RV.net editor you can either click on the link or image icons and attach your photos (max size should not exceed 800 x 600 pixels). Dial-up users can opt to NOT display images upon loading in their preferences set-up, so do not feel you must use the link feature - actual image posting is acceptable.
Thank you for sharing and please check in and contribute to the forum on a regular basis. There are many others out there who want to learn what you have accomplished.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
