budracer1
Aug 27, 2008Explorer
tvman44 wrote:
Ok "Y" & "BU" would be connected together, "BR" & "RU" would be conneted together. Then connect one pair thru a 30 amp breaker to your connector. If you have to add any wire be sure to use a large enough wire to handle the current. HTH
Ok now i am confused(LOL)which dont take a whole lot i might add.So i need to get a new breaker?also i dont see the ru wire on the diagram.I might also add that i have never even seen wires on a generator so i may need more in depth instruction,:h
professor...you may be right all i know is what it says on the side and that it has a 13hp chinese honda copy engine.
thanks Jason
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
