MrWizard
Aug 28, 2008Moderator
you could parallel the windings and put full amps at 120 on the twist lock and use a twist lock to RV adapter, use only (1) of the 23 amp breakers , but you might trip out the breaker when it comes time to run the A/C and the MW at the same time
the current configuration is 1 winding per duplex and 230v at 23amps at the twist lock, no way to go to 120 only with out moving wires, whether its cutting, or unscrewing, things have to be moved
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
