walkers2rad
Sep 07, 2008Explorer
Old & Slow wrote:
Richheck,
I noticed the plug in a local RV store last week. I need that for my home shore power cord. Guess I'll have to return and buy one.
Floyd
Using that at home will not quite give the same benefit as it does from a gen but rather a possible sense of false security in thinking one can pull more from the outlet than they should. With that said I dont necessarily think those should be sold to the general public. It does make a better connection to the outlet but may move the place where things get hot to inside the outlet box where the potential for fire is greater.
Most houses are wired so that both plugs dont pull power from different circuts between the two outlets in the wall. In a gen they may be on seperate circuts. Sure if you pull your outlet out you may notice that it has two sets of wires to it but one is power coming in and the other is going to another outlet. Sure one could be wired with two different circuts with this in mind from the beginning but not likely. So you would be limited by whatever your outlet is wired with, 14 gauge wire and a 15 amp breaker is going to be just that using this or the adapter you probably allready have. If it is on a 20 amp breaker and you have 12 gauge wire and so on. Pulling 30 amps requires 10 gauge wire minimum... 8 if it is a long distance. So consider the distance from that outlet box to the breaker when trying to pull extra power because too much distance can create a dangerous condition with wires heating up.
The key is knowing what your actual loads are and your limits.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 02, 2026
