Old___Slow
Dec 22, 2008Explorer
Prof,
On the subject of adding GFCI to our gennys. Several questions.
1. Assuming a 30a is available to replace the 20a recpt. in the C46540 can it just be jumpered to the 30a RV recpt? Only connect the white and black wires? And must I know if my MH has a floating neutral?
2. If I were to accidentally touch a black and white wire down stream from a GFCI, would the result be less dangerious than depending on a breaker. I assume the result from a GFCI @ 5ma would only be a slight zap. Maybe you could offer some differing results in safety. And any further thoughts about the vibration issue?
Floyd
Floyd
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
