tvman44
May 27, 2009Explorer
Probably should rejet carb.
lt_eggbeater wrote:
How many running watts can I expect at 6000 feet on a c46540 generator? I am getting about 1900 watts with a variation in hertz of 61 to 58. If I want totaly stable IE 59-60hz I need to back off to about 1400-1500 watts. The generator is maxed out at about 2300 watts but the hertz fall all the way to about 54 at this setting. This is feeding a Trace 4024 off grid inverter up at my mini ranch between snowflake and concho az. So I can set the max amps drawn from the generator on the inverter setings. Currently I have the inverter set to draw a max of 14 amps. Is this normal performance? I would think it would do a bit better than that.
Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
