roadyacht
Jun 12, 2009Explorer
Thanks. Ahh, the difference between knowledge and wisdom/experience.
It is said"the rules are taught to youngsters in school, and the exceptions are known by the old guys in the field"....
I had converted the "chonda" to tri-fuel; so I would not be stuck at the home site without power for an extended time,via natural gas(which is piped to my unattached garage for heat)and/or propane,which I store for several different applications.
The generator is not all that efficient in any iteration, and having power to run the home barely is all that I require.
As for the entry of the RV LPG extended stay fixture to couple to outside tanks?, get one!
I did and do not regret it; I run BBQ,faux campfire,lanterns,or any combination of those(with a splitter at the end of a 12'hose, with 2 5' hoses that terminate in the 1# female cylinder end fitting),and as a matter of fact,Farm and Fleet has an adapter to refill those little cans.
I don't know if it is safe, but it is neat.
The other threaded fitting in that pre regulator fitting configuration is to hook up a 40-100# tank, enough to run heat,hot water,etc. for a good long time in cool weather.
I put one on my "C" camper, and have one now on my "A" Roadyacht.
I love to cook, so it is essential I can have fire, and hot cleaning water.
I would convert my Onan genset to propane, but it isn't at the top of the to do list yet; I would add solar to my inverter first.
And yes, it is a faux sine inverter,and so far, nothing bad has happened, and it is the one I installed/removed from the "C" camper I traded.
4 years and counting...9 months of the year to camp in the mid west.
Thanks to you all, we are going to the FMCA in Rockford, posting from there friday nite.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
