tubular031
Jul 15, 2009Explorer
professor95 wrote:
The float bowl will need to be removed and cleaner sprayed up into the jet orifice (wear safety goggles!!!!). You may even need to unscrew the jet from the carb body to get it clean.
Thanks for the input professor! I called champ this morning and they told me the same thing. I just wanted to make sure with champ that if I start to pull things apart, it will not mess with the warranty since its only a few months old.
Why is it that my lawnmower and lawn tractor can sit for 4 or more months in the shed during the winter and fire up fine in the spring? The first year I put some stabil in there but am almost sure it did not get any this past winter. ( I know BAD BAD BAD!! life threw a MAJOR b-slap at us right around that time :( ) is it just because of the design of the carb/float/jet?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
