mecreature
Jan 05, 2010Explorer
waybo418 wrote:Todd Barney wrote:StaJs wrote:BORoarke wrote:
Anyone have a picture of where you put the RTV silicone on the white fan to reduce some of the noise from that end? Or can explain the process?
Bryan
HERE
Scroll down toward the bottom of the page. The original post seems to have disappeared, but you don't need to remove the starter first, remove the starter and housing as a unit.
Did mine today. Here are a few pics.
Approximate location of the starter and housing unit bolts are here. (Pic wasn't taken at the right angle to actually show you all of the bolts, but they're pretty obvious.)
Next comes the flywheel nut. This is 19mm, or a 3/4" socket fits, also. I used an air wrench to bump it off. Putting it back on, I stuck a big screwdriver through the holes on that silver thing so I could apply some torque.
Here's a pic of the exposed flywheel. I drew in the places where I put the sealant.
I used threadlocker on the nuts and bolts when I put it back together. I'll know tomorrow after it cures whether it helped with the sound or not.
Purchased my new Model 40026 today at Lowes (had a coupon, so it cost me $304) I haven't deceided on the extended warranty yet, but I have 30 days to make up my mind. I didn't have the chance to fire it up for the break in, but it will have to be done soon as we are taking it to the Charlotte race in a few weeks.
On my way through the posts, I noted the one above. Is this something that I should do or not?
does this apply to the 40026 model?
just curious... nice little gen..
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
