MrWizard
Mar 31, 2010Moderator
when i had it on the slide, i left the exhaust std and did not modify it
because with the tray out, everything was in the open.
I only ran the champion with the slide out.
you could add a flex pipe ext to the end of the exhaust if you need to point it away from the fiver
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
