Skibane
Jun 04, 2010Explorer II
VDOCAD wrote:
I cannot get the RPM right: checking the microwave's timer against a separate digital timer, the microwave is running too fast(13 sec faster) than my hand held timer. Turning the yellow screw CCW(several turns!!) I can make the microwave's timer match my hand held, but the engine speed is now so slow that the microwave kills it.
Try adding a few hundred watts of load to the generator while you're setting the engine speed to match your hand held timer. With a very light load, the generator may be producing a waveform that "fools" the microwave timer into running fast or slow - adding an additional load may eliminate this.
Also, have you confirmed that the muffler and spark arrestor are not plugged up? This can make the engine lose power.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
