jasult
Jun 04, 2010Explorer
VDOCAD
Did you ever take the bowl off the bottom of carburater?
Float could be sticking or gummed up. Remove air cleaner and float and spray gumout in the bottom to clean out all passagways. It only takes small clog to cause it not to run under heavy load but still runs ok with no load. Pull fuel line off carb and make sure it flows out good and not slow drip out of bottom of tank or the fuel shut off is not restricting fuel flow.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
