Wrace
Jun 18, 2010Explorer
professor95 wrote:
You mean like this:
The only difference is possibly my exhaust extension going through the topper roof.
The air in the camper shell heated up quickly -- too quickly. I ended up having to put a 20" box fan at the front of the bed where the slider window was open to blow air out the open rear hatch over the tailgate.
This was the weekend that my AVR failed - possibly due to too much heat.
I really think you are asking for problems with all the stuff you are proposing. As I have noted before it is easier to cool an enclosed genny with a small compartment and fan that directs air flow than a larger compartment that just blows air. Having the camper shell around the enclosure will compound the problem.
My advice is to quit worrying about noise. Run the genny during generator hours and while others are running theirs. It's sound level will be fine under those conditions.
Ok, thanks. I had a feeling it sounded too easy to be true.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
