pritch272
Jul 07, 2010Explorer
Boy Racer wrote:
"With no load, on 120V setting, the generator was producing a pretty
steady 13.9 - 14.2 amps. The fan as a test load had a negligible
effect on the amperage read out; the hair dryer test would drop the
amps to around 13 even; and the vacuum would drop it to about mid-10s
to low-11s. The vacuum and hair dryer together would pull the amps
down to mid- to high-8s, but again, the shaking and erratic RPMs meant
the unit was not functioning properly."
? Doesn't make sense. Current produced is directly related to demand on devices connected and turned on. Current should not decrease as more stuff is powered on.
No load should be no amps.... Something is consuming the power, perhaps a converter?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
