professor95
Jul 08, 2010Explorer
byates wrote:Max49 wrote:
I really like or want to like the Champ but I think they were stretching it with their liberal Watt rating. Mines 3500/ 4000 and 2 1500 watt appliances (heater and heat gun) tortures it. But to be fair, I'm in Colorado at 6000' +
I believe you are right that the Watt rating is overstated. The Onan Homesite Generator rated output is 2000/2200 watts with the same size engine. But of course, Onan could be understating the output.
A realistic output is probably around 2500 watts. I used to know the formula to calculate a realistic output, but old age made its appearance, and I can't recall it and don't feel like looking it up. Exceeding 2500 watts on a regular basis can't be good for the longevity of the unit.
The world is full of advertising claims that are "shaky" at best. While the Champion "may" indeed put out a solid 25 amps to a resistive load it is NOT, IMHO, nor has ever been a 100% duty cycle 3,500 watt generator - nor have others using the 200 cc GX clone engine. I have always stated that you have a dependable 2,800 watt generator. Anything over that is intermittent and sustained operation at higher loads will drastically shorten the life of your machine.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
