MrWizard
Jul 25, 2010Moderator
That's starting at around 11amps load chargingbatteries with a 55amp WFCO the load decreasing as the batteries charge, also including turning the converteroff for long enough to use the mw to bake a potatoor heat up something then turn converteron again, so the load was not.constant value
lt_eggbeater wrote:
is that 5 or 6 hrs at full load or half load.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
