bill_h
Aug 07, 2010Explorer
SonicLogic wrote:
You need to determine the brand and the model of the A/C unit you have in your RV. For example, the Coleman Mach 15 puts out 15,000 BTU’s and draws about 16 amps. The Duo-Therm Brisk Air 13,500 BTU A/C draws about 14.5 amps. Once you know the brand and the model, you can look up the specifications on the Internet.
Many AC units have the information on a tag inside, usually seen when the filter or interior shroud is removed.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
