Old___Slow
Aug 14, 2010Explorer
John, Prof' likes to call you Dr. Austin. For this post I'll just go with John. Just not Dear John;)
Here is what I experienced with relocating the muffler out of the box. I was never able to overcome the heat of the manifold/exhaust. I think you will find 400 plus degrees in the pipe for some distance. Muffler wrap 'might' do the trick to lower this temp. Using a 400 plus degree boiler wrap I was unable to touch the insulation cover. At that point, I decided I would never relocate the muffler. If you find true binefit when the job is completed, that will be needed info' for others wanting to construct an ideal, sound lowering box. I continue to promote the use of the 1/2" 4' x 8' sheets of sound board (the black stuff) from either Lowe's or HD. The board I used is stamped (from HD) 23 STC. Looks like celotex. What I hold to is it's more important to absorb the noise of the gen, not just block or stop sound transmission. I would like to know if you have an opinion of any binifit by using the Hardi product as a first layer. Anyway I'm down to being able to lower the noise from my Champ by 15 dBA with using only the 1/2" sound board and off- setting all air intake and exhaust. No direct 'open' view of the gen. And placing the gen on carpet. The Rubber mating Prof' uses would be perfered. This thread has been a great learning experience which continues. Kidos on your project. Carry on.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
