professor95
Sep 01, 2010Explorer
At this point in time, Champion is the only 3,000 watt class Chinese built generator available in American markets with the 30 Amp RV TT outlet.
Others may offer the 30 amp twist lock outlet but it requires an adapter to connect to the RV power cord adding to the overall cost.
I'm not advertising for CPE nor am I saying that these other Chinese generators should not be considered. Just think about what you may be really spending on a non-RV ready model.
While the current crop of Chinese 3,000 watt class generators continue to use the 196 cc GX200 class engine - which is pretty much the same across the board as far as durability and performance - there can be a HUGE difference in the way the alternator is built. The gauge of the wire used to wind the coils, the type of insulation used and it's ability to withstand high temperatures, the rear carrier bearing and AVR. I have seen quite a few of the designs and materials used by many of the "low end" models and was disappointed in several brands.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
