RTompkins3
Sep 07, 2010Explorer
professor95 wrote:
Let's see now..... Kipor in ECO mode with no GenTent = 53dbA, With a GenTent it is below 50 dba.
Kipor in high speed mode with no GenTent is 60 dbA, with the GenTent we drop to 56 dbA. A 4 db reduction is significant. But, why wasn't the sound drop equal to the bigger generator in my previous tests?
Well, much of the noise you hear from an open frame synchronous generator like the CPE 46538 is mechanical banging, bumping and vibrating. The cases on the inverters are designed to considerably muffle that particular frequency range. So, even though it may sound sort of fuzzy, there really is not as broad of a sound frequency range to block with an inverter. As with any "reduction" device, there is a point of diminishing returns.
I actually use the Kipor more on my boondocking trips to the mountains than the big Champion 40008 permanently located in the front of my 5th wheel. I rarely need the 15,000 BTU A/C in the mountains so the Kipor provides more than enough power. But, in the NPS Campgrounds on the Skyline Drive lowering even the sound level of a mid-size inverter that mimics an angry swarm of bees when under load will be a plus. I was very pleased with the results.
Professor -
Another thought - raise the Kipor up about 4 inches so that the tent shields all of the generator around the edges and then see what the difference is. Making the noise have to "turn the corner" at the base might make a difference and with the small size of the Kipor it shouldn't affect the cooling all that much.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
