SonicLogic
Oct 03, 2010Explorer
pritch272 wrote:
OK, why not use Seafoam in the fuel? :h
By volume, Seaform contains up to 20% IPA (isopropyl alcohol). Ethanol alcohol is now blended into most gasoline sold in the U.S. Depending upon where you live, the gasoline available to you could be blended with up to 10% ethanol alcohol (so called E10 gas). All engine manufacturers specifically warn against using gasoline formulations containing more than 10% alcohol by volume. You do the math.
Check here.
Also, don't ever use Seafoam in your oil.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
