MrWizard
Oct 03, 2010Moderator
ie "use of fuel"
If you put sea foam in every tank of fuel then you are not increasing the ethanol fuel level you are adding Isolproponol
Using it occasionally to clean the system is "service work " not regular fuel consumption
My cummins diesel has ether injection for cold weather conditions starting,
I would never run the engine on ether mix, but it won't hurt the engine to use the ether to start it
THE MANUALS do not say "Never use fuel additives," never clean the carb etc.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
