Cox89XJ
Dec 29, 2010Explorer
Cox89XJ wrote:MrWizard wrote:
sounds like a problem with the speed.governor & linkage
change the oil, run it a.couple hrs with no load it might loosen up,
spray all the throttle linkage and governor with a good penetrating "OIL" like Kroil, Pbs blaster, jb80 etc.
I've checked most of that, I just ordered a carburetor online for approx. $35 dollars, hope that fixes it. If it doesn it's going to the junk yard.
Update:
The new carb did not fix it. It does the same thing. Will start and only run a few rough seconds and die. Restart and does the same. Acts as though it runs out of gas, it's getting plenty of gas to the carb, replaced spark plug, Any suggestions?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
