regal5575
Jan 22, 2011Explorer
Boone,
What you are referring to are "Top Tier Gasolines". There are several brands that meet the requirements and are qualified Top Tier gasolines.
Go here for more information on Top Tier gasolines:
http://www.toptiergas.com/index.html#
or
Click here for Top Tier info
JerryK
or
JerryK
byates wrote:Cox89XJ wrote:
The repair guy also said he would use the highest grade gasoline because it is a lot cleaner than regulator.
Your repair person is correct to a degree. Some brands of gasoline do contain a higher amount of cleaning additives in their premium brand vs their regular brand. Shell V-Power gasoline is one that comes to mind.
In lower compression engines, it is difficult to ascertain any difference in performance between the various octane levels of the fuel used. All grades of gasoline contain roughly the same amount of energy. The amount of carbon residual is a factor of the engine design, engine condition, and the quality of the gasoline and its additives.
If you have a lower compression engine and want the additional cleaning capability found in some brands’ higher octane gasoline and willing to pay the difference, the only cost is to your wallet, not your engine.
Boone Yates.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
