jasult
Feb 13, 2011Explorer
Professor, have a question on my 3500/4000 model 46514 The last few days I have been running my heavy 7 inch grinder that is 15 amp and every few minutes the champ would shut off. First thing after checking oil and was good i disconnected the low oil shut off but that did not help.Fuel supply looks good as I removed bowl and checked flow with float working. Even with choke half on when cold did same thing.
If i run my smaller 4 inch grinder all is good but the 15 amp grinder causes it to stall but always restarts with 1 pull. I would have thought the breaker would trip not the engine stall.
On the web site they talk about the avr voltage adjustment and in 120v side it should be about 130v. Mine shows 120v. Any thoughts??
thanks, jim
thanks, jim
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
