jasult
Feb 13, 2011Explorer
thanks for reply's. My grinder is 15 amp and I would not think it would have been problem. Yesterday I did pull off fuel shut off bottom and fuel flowed good as well as I pulled off carb bowl and fuel flowed good. I will add some sea foam to fuel as well as change spark plug and see. I have to use the grinder again Monday so I will test it again.Spark arrestor is also fine. I had same problem last fall while dry camping at Hershey Park. I thought someone flipped off the switch a few times as it would start right back up. This Champ was bought last summer and not more than 20 hours total on it. Yesterday I plugged the 7 inch grinder in with the short 6 foot wire and clicked on and off the grinder a few times and sure enough it stalled several times. If I just let genny run with no load it seams fine.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
