professor95
Feb 13, 2011Explorer
Max49 wrote:
I believe this is a 25 Amp 120 volt receptacle. It's pretty much wasted for me because I have nothing with this kind of plug, Lowes or Home Depot have no adapter to make it a normal plug. Does any one know where I can get an adapter to make this 25 amp plug useable. The other normal plugs are only 15 amps.
Your plug is a 30 amp 120 volt NEMA L5-30, which is a twist and lock blade type plug designed to keep the cord from falling out due to vibration or a tug.
There are a number of different NEMA configurations that depend on amperage, voltage and grounding.
Amazon shows the adapter you are looking for here for $25.70. I doubt that you could buy the individual pieces to make your own adapter for less.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
