TeamSlacker
Feb 18, 2011Explorer
Good luck Dan :) and I only say that because one showed up on my doorstep yesterday too.
Not happy that it shipped full of oil apparently, which now has coated most of the gen and soaked thru the box.
Haven't fired it up yet, need to complain to the seller first, and then clean it up.
Have you noticed there seems to be 2 versions? One with a smart/eco throttle switch in the lower left corner of the panel, and the other has a sticker in that area, I got the later, no switch. I did remove the carb cover on the case, and peeked at the carb, it appears to have a stepper motor on top, so curious to see if mine will have variable throt or not. Basically, wasn't sure what I was buying, but figured what the heck.... give it a shot...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
