TeamSlacker
Feb 23, 2011Explorer
Just a small update: Put the AP 2k inv back together last night after cleaning up the valdez slick.
My prior ETQ tests were in the open in the back yard, with gen sitting on grass. with a low of 58db. Last night with the ETQ on concrete and snowbanks around the driveway, I saw 63-64db. The AllPower was 67-68db under the same conditions and same side (panel opis of exh) I was still hearing a loud plastic rattle, seems to be coming from fuel filler neck to case junction. I was out in the cold alone so didn't have anyone to stop the rattle while I steped away and read the db meter.
If I have some time this weekend I'll try some more tests, maybe with bigger load, and also check the output with the kill-a-watt and on the o-scope.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
