Dan86300zxt
Feb 28, 2011Explorer
Thanks Professor and TeamSlacker.
^^Looks like the PD9160A (60amp,1000watts continous 120v input required)
is what I am going to go with...I'd go with a larger 70 or 80 amp, but two things tell me to be careful...the size load on the generator and the lack of understanding if there are any peaks/surge power requirement for these chargers when in boost mode.(I'm am failing to realize what Professor is trying to tell me about not worrying on the PD design chargers.)
*I did some measuring today and it looks like I am going to be going to Sams Club for 6 GC batteries.(lol, managed to come up with the funds to make life work)
**Yes, Professor...I am very aware of the sensitivity of the specific items for the generator and the need for sufficient airflow/cooling.
I will be engineering the MH compartment to move more air than what the manufacture has designed into the completed original generator and relocating certain items further away from heat.
***I found my MH has a 5/16" fuel injection hose with a shut-off valve coming from the original gas tank.(looks like its located at about the 1/4 fuel level height.)
-I am spinning the idea of putting a cheap low pressure pump inline with this to a custom smaller stainless steel tank that has a liquid level switch to control the pump...leaving the custom tank as a gravity feed to the carb on the generator and venting the tank to a charcoal canister I have.
-The charcoal canister can be "T'd" into the Valve cover vent for the generator to suck the fumes through the air cleaner and into the engine for combustion.
^^^Hmmm...this way I am merely looking at the mounting of the engine and generator with the electrical slightly relocated...no large goofy sized plastic fuel tank to deal with or any of the plastics period. I am also looking at the cooling fan that can be removed from this engine...it seems to me, in principle, that the original engine fan is going to mess with my airflow design for the cabinet. I am planning to funnel two 4 amp/900cfm fans worth of airflow through this cabinet(a suck blow total of 8 amps/1800cfm).
Dan
Dan
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
