professor95
Mar 03, 2011Explorer
Dan86300zxt wrote:
-Question is..."What do I do with these ground or bonding points on each one of these new pieces of equipment I am adding to my MH.
Is there an update I should be doing to the a/c wiring and outlets to be safer?
HELP!!
Dan,
I need to know something.
The shore power cord for your motor home... If it is for a 30 amp supply, does it have three wires? If so, is the grounding wire (green) attached to the vehicle frame? If not, where is it attached?
If it is something other than 30 amp (20 amp or 50-50 amp) please explain the connection to the vehicle of the shore power connection.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
