rizwan
Mar 05, 2011Explorer
Im using 3000w Loncin chinese generator from last 1 year. which run 5 fans and 1 deep freezer and some lights.
I have some question?
1. I run this generator 3 hours daily on natural gas the spark plug gap is 0.20 mm and it is NGK bp6ey V power i need to know the gap of plug and the plug itself is ok i mean if i move the gap from 0.30 mm to 0.40 mm the generator is very hard to start.
2. Engine is 196cc what is the valve clearence of the engine i lost the manual but i adjust the valve on this specification exhaust 0.20mm and intake is 0.15mm (cold).
I need to know if clearnce are too tight or too lose does makes any problem please explain it.
3. Im using the oil for crankcase is 20w50 caltex havoline deposit shield and change it after 200 hour is it ok.
4. I did not use gasoline since i convert my generator on NG so the gasoline tank is useless for me can i remove it from generator does it any harm from cooling point of view.
5. When generator is started it shows a voltage on voltmeter of 220 volt accurate and after an hour the voltage is decline to 215 volt on same load what is the reason behind this.
6. Explain the lubrication time of alternator stator bearing.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
