professor95
Mar 31, 2011Explorer
DSchmidt_2000 wrote:
When the kill switch is used on a generator, is just the ignition that is turned off? If so then where does the sudden collapse of the generator field occur? Field should just decay as the RPM's drop, no?
You are correct. It is not a sudden collapse. There is no instantaneous disconnect like pulling the power plug on an inductor. My brain sometimes moves into a gaseous mode.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
