professor95
Apr 02, 2011Explorer
deadeye1 wrote:
Prof,
Thanks for the info.
I have a much saver idea. I'll sell this unit and buy a new one at Tractor Supply on our next camping trip to NH that is already setup with an RV plug.
Good idea! Your model generator is great for home power outage use, contractors needing split 120 volt outlets for two power tools like circular saws or a low amperage appliance needing 240 volts - but it is not well suited for RV'ers wanting a single 30 amp 120 VAC outlet (25 amp supply).
Lots of folks have rewired their units to parallel winding generators, but unless you have experience doing electrical work and fully understand the process it is best leave it "as is" and buy one factory wired for RV use.
If you can afford the extra bucks (or even find one - TSC does not sell it) the 46538 and near identical twin 46512 are absolutely awesome synchronous generators. I love the remote electric start.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
