Dan86300zxt
Apr 16, 2011Explorer
TeamSlacker wrote:
I planned on leaving the new AP2kw alone till I could do some more db tests, but the rattle got the best of me and I tore it apart and picked up a couple cans of ruberized undercoating. Here's a peak inside.
http://flic.kr/p/9nP5CE
http://flic.kr/p/9nP61u
**I figured I'd throw in an update...
-I have torn my AP2Kw apart and completely reverse engineered it for mounting into my MH cabinent.
*(I notice yours has the charcoal canister??...mine is identical in every way except, no canister. SPecifically, I am speaking of the vacuum line and associated item you have pictured laying on the top of the fuel tank and leading down near the air filter)
(much, much easier to do than I thought it would be)
Just a heads up for anyone with one of these units...Take and remove the outer plastic casing and go through checking/tightening everything you can get your hands on!!!
-almost all my hardware fastening things to my gen was "loose as a goose", (with exception to the muffler bolts, most of the bolts holding the engine together, and the carb).
^^I was surprised at things like motor mount bolts and motor frame extension, even the plastic outer covering all LOOSE.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
