Dan86300zxt
Apr 19, 2011Explorer
MrWizard wrote:
Dan
If you use manual switches it should be done with one multi pole switch Or with some kind of mechanical lock out so only one switch can be engaged
The safety aspect (to prevent fire or injury) can not be over emphasized
I know one fellow who put two RV outlets in the power cord compartment, one wired to the generator, one wired to the inverter,
He plugs the shore cord into power source he wants, genny, inverter, shore pedestal,
Totally fool proof and failure proof
I understand exactly what you mean....setting things up the way I am is a complex ordeal. This part of the wiring I had not put much thought into, and figured posting would force me to get it done, get it sorted out, and to get others opinions.
MISSION ACCOMPLISHED!!
I have it all mapped out in a diagram(makes perfect sense to me). Explaining it with words on the screen to everyone makes it harder to understand how its going to work. I'm sure pictures of the finished installation and set-up will make it more clear.(A link to Pix will be coming when I am done)
Thanks everyone!
Dan
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
