MrRchitty
May 01, 2011Explorer
professor95 wrote:
Just sharing.....
I have an electric start Champion 40008 skinned out and converted to propane in the front compartment of my fifth wheel. For anyone that wasn't around when I did the initial write-up, cooling is accomplished by a down draft fan that is in a box under the generatordown draft fan that is in a box under the generator. A second fan is attached to the end of the alternator to assure cool air flow across the AVR and insides of the alternator.
Professor,
Down draft fan? Does this bring all of the heat from the generator across the fan motor? Any problems with that motor handling the heat?
I would like to construct a box using your ideas and would like to know more info about a down draft fan and perhaps where I could purchase one.
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
