professor95
May 04, 2011Explorer
daystrom wrote:
I bought a wheel kit for my Champion today. To my surprise other than making it easy to move around, it seems quieter now! The wheel kit raised the generator off the ground about an inch. Would that actually quiet the generator down a bit or is it my imagination?!
It is not your imagination. You have improved isolation from the frame to the surface under the generator. The little OEM rubber pads that may be under the generator do not provide much if any isolation. Vibration transferred directly to the surface is eliminated with the wheels and larger rubber feet on the front. You will notice the difference with the generator on a hard surface like concrete or asphalt. On dirt or grass it will make no difference in the noise level.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
