Dan86300zxt
May 10, 2011Explorer
professor95 wrote:Dan86300zxt wrote:
A few carb adjustments and back to good.
Dan
Just curious - what carb adjustments were you able to make?
*There is an idle adjustment screw and what I believe is a fuel adjustment screw(I might be wrong, might be an air screw, but it acted just like a fuel screw!!).
Either way...
-with the extended intake attached, I had to back the fuel screw out almost two more turns and had to leave the choke partially on to get it to run(choke is merely a butterfly that blocks the intake and I would guess that it was moved to block a very small portion of the incoming air).
**I know the problem was not the diameter of the intake I was using, as I used both bigger and smaller than the bore of the carb with similiar results.
***I believe it was an "air velocity" issue.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
