tvman44
Jun 08, 2011Explorer
Yes, the ground is not bonded to the neutral on most generators. You can do 2 different things #1 flip the bypass switch on the monitor to bypass position. #2 or do what I do "take a 15 amp 3 prong plug and put a jumper in it from the ground pin to the neutral pin and plug the jumpered plug into the 20 amp receptacle.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
