tvman44
Jun 10, 2011Explorer
Turn the screw CCW to reduce the voltage. I had to adjust mine the other day.
professor95 wrote:HobbyTalk wrote:
Thanks everyone for the info. I normally don't use the EMS with a generator but since this was new I figured I'd see what it said. I did find out the voltage out of the Champion is a bit high at 131v so I have to find how to adjust that down a bit.
Voltage adjustment is buried somewhere back in this thread. Short version is:
- remove end cover on alternator.
- remove bolts that secure AVR.
- Turn AVR over so you can access "potted" side.
- Look for small brass screw on potted side.
- Using a small screwdriver turn screw to achieve desired voltage.
- NOTE: The screw is a 10 turn potentiometer so do not be concerned if you must turn it several full 360 degree turns.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
