MrRchitty
Jun 12, 2011Explorer
MrWizard wrote:
I might be mistaken
but usually any charge rate adjustment is there so you can turn down the power draw to match the shore power source, meaning reduce the charge to say 30 amps, when you are plugged into a relatives 15amp duplex outlet
for the generator, if you don't need the power for other things like the MW or the A/C leave it at 100a output, the batteries will only accept what they will, charge acceptance is set by voltage & battery resistance
IF you need to run the A/C while charging, then wait until the charge rate drops off, or set a lower output rate so converter draws less from the generator and it will will have enough power left over to carry both the converter and the A/C
My camper has been plugged in for about two weeks and I checked the voltage from WFCO. It is still showing 13.6 volts. It should be 13.2 volts. Anyway....
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
