olephart
Jun 12, 2011Explorer
Thanks for your patience. I am an electrical maroon. What caused me some confusion is the converter has a different setting to automatically limit/balance the charger current.
You set whatever amperage you want to go to the appliances, Say 20A on 30A shore power. The charger will get the current specified in the first setting we discussed, say 60A until the appliance load approaches the value set 20A.
As the appliances approach 20A, battery charging is scaled back to maintain 20A to the appliances at all times. At that point, the charger would have 10A @ 120V.
You could set this to zero if you wanted all power to the charger.
Sooo.... I was thinking (figure of speech) that the charging amps setting was to comply with the battery manufacturers recommended charging rate. I'll just set it around 60A and let the other setting decide how much actually goes to the charger.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
